Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's Arm-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2337 or EMC 3598.
175вопросов Показать все
LCD displays image for 3 seconds only but backlight stays on
Hi there,
I am having an issue with an MacBook air M1. The LCD displays a perfect image but only for 3 seconds and turns off. The backlight stays on as it should and I can adjust the brightness too. I can repeat the issue as long as I either close and open the lid or hit a key on the keyboard.
I thought about the lid sensor, but it seems to work normally. The computer works normally with an external monitor, and is able to recognise it's own LCD and switch to single monitor mode whenever I close it.
Thanks for your help!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
I would visit an Apple Store ASAP as you still might be covered under warranty!
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Matt будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 46
