There is a headphone jack stuck in my phone
There is 2.2 mm headphone jack stuck my phones socket.I need to remove it without using glue
Это хороший вопрос?
Это хороший вопрос?
Hi
You might need to replace your headphone jack depending on how deep it is in but here’s something to try
If you don’t want to use glue you can take it to a reputable repair shop or get a dremel and drill into the middle of the jack(make sure to not let it damage the port though)then once you have a big enough hole in the remaining jack try and get some fine tip tweezers and pull it out
Like I said it might be a good idea to have a professional see it before trying anything serious
Hopefully this helps
Any questions please ask
Был ли этот ответ полезен?
Open up the phone and push it out from the inside. There's a hole at the end of the jack inside you could put a paperclip in and push the part out.
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 190
