Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
294вопросов Показать все
iMac keeps corrupting disks
In 2020, I purchased a brand new 2017 5K iMac which enclosed a 2Tb fusion drive, that is a 128Gb Apple (Samsung) NVMe SSD + a 2Tb Seagate HDD.
16 months later, the fusion drive crashed due to the hard drive being crippled with bad sectors.
Stuff happens, I thought...
I changed the original NVME for a 2Tb Samsung 970 EVO plus, and the original hard drive for a Samsung 870 EVO, both disks being highly rated everywhere.
Everything went fine for 15 months, but suddenly, the 970 EVO plus on which MacOS was installed locked itself into read-only mode because 100% of its SSD spare blocks had been used. Drive DX reports more than 5000 media and data integrity errors, for just above 16 Tb written.
The 870 EVO seems about to follow the same course, with 1040 spare blocks used, (50% of available spare blocks), and a flash read fail count in the thousands, for just 5Tb written !!!
My question is : What is the most likely cause for this behaviour ?
Has anyone had such a bad experience with an iMac ?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (3)
Наиболее полезный ответ
Yep that is what I often encounter when using an M.2 blade SSD instead of the proper Apple designed SSD or one of the 3rd parties which properly design the SSD for the sound up to emulate the Apple unit.
So you'll need to take the Samsung 970 EVO plus out and put in its place either iMac Intel 27" (Mid 2017-2019) SSD Blade Upgrade Bundle or Custom Samsung 2TB SSPOLARIS SSD
The error condition can also be due to the Fusion Drive setup was not cleared fully as you really don't want it with a dual SSD setup.
iMac Intel 27" (Mid 2017-2019) SSD Blade Upgrade Bundle Изображение
Продукт
$99.99
Был ли этот ответ полезен?
Оценка 2
6 Комментариев:
Hi Dan,
thanks for your reply, but while I understand that Polaris drives were designed specifically for the iMacs and should last longer than other drives on the market, I tend to think that the rapid failure of not one but three drives in the same iMac after less than a year of use for each of them is highly suspicious and should lead to a diagnosis of the PSU and the motherboard, before investing in a $500 solution.
Is there any accessible way to tell if the PSU and MoBo are OK ?
из
@benedictfranz - I can't see how the PSU would be a factor here, you would have more glitches within the CPU and GPU logic before the SSD would be effected.
The logic board might be a issue, but you didn't state having encountering OS crashes so that removes it as in this case the logic connections are different between the two ports. Here we have both a SATA and a PCIe/NVMe connection.
So again I can't see the issue is within the logic board as these two connections use different elements within the logic board. But! A misconfigured OS or something running like a virus or malware could be the cause.
Are you file sharing with anyone over the internet? What is your workflow? Music or Video work? Photography? CAD/CAM or DB development? Online Gaming?
из
Thanks for the explanation, @Dan.
You're right, if the logic is different between SATA and PCIe, a Motherboard problem is unlikely. The only problem I had with that mac was in relation to the drives failing, everything else is smooth.
I work on Java projects and databases, but not at a professional level, this is mostly a home machine, so, nothing really special I can think of. Besides the SATA drive was used essentially for storage purposes, hence the very low 5TBW.
At a moment, I came to link the high number of hardware resets returned by DriveDx (6400 for just over a year of usage) to the Power Nap functionality, and I was wondering if this could have any impact on a drive's life expectancy ?
из
How about posting the full DriveDX output on the drive/s so I can get a better idea on what you are encountering.
It’s possible you are leaving a file open when you let the system sleep which is why I prefer to shutdown Vs letting my system sleep for more than a few minutes.
из
Very interested by the opened file track. I do indeed keep many files open all the time, because, you know, that's what sleep is for : you leave it here, you find it here when you're back the next day.
How could that damage a drive ?
из
Показать 1 больше комментариев
Meanwhile, first Drive Dx export for the 970 Evo + drive :
  1. SYSTEM INFORMATION ###
Report Timestamp : 5 octobre 2022 22:38:09 UTC+2
Report Timestamp (ISO 8601 format) : 2022-10-05T22:38:09
Application Name : DriveDx
Application Version : 1.11.0.730
Application SubBuild : 0
Application Edition : Standalone
Application Website : https://binaryfruit.com/drivedx
DriveDx Knowledge Base Revision : 101/101
Computer Name : myMac
Host Name : myMac
Computer Model : iMac18,3
OS Boot Time : 2022-10-04T21:51:51
Time Since Boot : 1 day 00h 46m 18s
OS Name : macOS
OS Version : 10.16.0
OS Build : 21G115
OS Kernel Version : Darwin 21.6.0
SAT SMART Driver Version : N/A
ATA Command Support Tolerance : verypermissive
N of drives in report : 1
  1. DRIVE 1 OF 1 ###
Last Checked : 5 octobre 2022 22:22:51 UTC+2
Last Checked (ISO 8601 format) : 2022-10-05T22:22:51
Advanced SMART Status : FAILING
Overall Health Rating : BAD 0%
SSD Lifetime Left Indicator : GOOD 100%
Issues found : 4
Serial Number : xxxxxxxxxxxxx
WWN Id :
Volumes : Macintosh SSD
Device Path : /dev/disk0
Total Capacity : 2.0 TB (2 000 398 934 016 Bytes)
Model Family : Samsung 970 EVO Series SSD
Model : Samsung SSD 970 EVO Plus 2TB
Firmware Version : 3B2QEXM7
Drive Type : SSD
Power On Time : 7 139 hours (9 months 27 days 11 hours)
Power Cycles Count : 5 611
Current Power Cycle Time : 24.8 hours
DEVICE CAPABILITIES
S.M.A.R.T. support enabled : yes
DriveDx Active Diagnostic Config : Samsung 970 EVO Series SSD config [ssd.nvme.samsung.970.evo.01]
Sector Logical Size : 512
Sector Physical Size : 512
Physical Interconnect : PCI-Express (PCIe)
Logical Protocol : NVM-Express (NVMe)
Removable : no
Ejectable : no
NVMe Revision Supported : 1.30
PCI Vendor Id : 0x144d
Thermal Throttling Supported : no
Volatile Write Cache Supported : yes
Maximum Data Transfer Size : 128 Pages
Log Page Attributes : 0xf
Format NVM Attributes : 0x5
Optional Admin Command Support : 0x0
Optional NVM Command Support : 0x57 (Compare, Wr_Unc, DS_Mngmt, Save/Sel_Feat, +)
Number of Power States Supported : 4
Error Log Page Entries : 63
Keep Alive Support : 0
Total NVMe Capacity : 2 000 398 934 016 (2.0 TB)
Unallocated NVMe Capacity : -
Number of NVMe Namespaces : 1
I/O Path : IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/RP17@1B/IOPP/SSD0@0/IONVMeController/IONVMeBlockStorageDevice@1
[Known device ]: yes
[Drive State Flags ]: 0x2000014
CURRENT POWER CYCLE STATISTICS
Time since computer startup : 24 hours
Data Read : 440 983 040 bytes (441.0 MB)
Data Written : 0 bytes (0 B)
Data Read/hour : 17.8 MB/hour
Data Write/hour : 0 B/hour
Operations (Read) : 103 771
Read IOPS : 7 156
Operations (Write) : 0
Write IOPS : 0
Throughput per operation (Read) : 4.2 KB/Op
Latency Time (Read) : 0 ns
Latency Time (Write) : 0 ns
Retries (Read) : 0
Retries (Write) : 0
Errors (Read) : 0
Errors (Write) : 0
PROBLEMS SUMMARY
Failed Indicators (life-span / pre-fail) : 0 (0 / 0)
Failing Indicators (life-span / pre-fail) : 2 (0 / 2)
Warnings (life-span / pre-fail) : 0 (0 / 0)
I/O Error Count : 0 (0 / 0)
IMPORTANT HEALTH INDICATORS
ID NAME RAW VALUE STATUS
7 Data Units Written 31 617 078 (16.2 TB) 100% OK
14 Media and Data Integrity Errors 5 339 100% Failing
TEMPERATURE INFORMATION (CELSIUS)
Current Temperature : 51
Power Cycle Min Temperature : 21
Power Cycle Max Temperature : 51
Lifetime Min Temperature : 21
Lifetime Max Temperature : 52
Recommended Min Temperature : 5
Recommended Max Temperature : 82
Temperature Min Limit : 5
Temperature Max Limit : 85
DRIVE HEALTH INDICATORS
ID | NAME | TYPE | UPDATE | RAW VALUE | VALUE | THRESHOLD | WORST | LAST MODIFIED | STATUS
2 Composite Temperature Life-span online 51 (51 °C) 49 15 49 05/10/2022 22:22 40.0% OK
3 Available Spare Pre-fail online 0 0 10 0 20/09/2022 21:41 0% Failing
5 Life Percentage Used Life-span online 0 100 0 100 - 100% OK
6 Data Units Read Life-span online 104 257 933 (53.4 TB) 100 0 100 05/10/2022 22:22 100% OK
7 Data Units Written Life-span online 31 617 078 (16.2 TB) 100 0 100 20/09/2022 21:41 100% OK
8 Host Read Commands Life-span online 1 649 199 428 100 0 100 05/10/2022 22:22 100% OK
9 Host Write Commands Life-span online 755 316 185 100 0 100 20/09/2022 21:41 100% OK
10 Controller Busy Time Life-span online 3 289 (3 289 minutes) 100 0 100 30/09/2022 12:44 100% OK
11 Power Cycles Life-span online 5 611 100 0 100 05/10/2022 21:01 100% OK
12 Power On Hours Life-span online 7 139 (7 139 hours) 100 0 100 05/10/2022 22:22 100% OK
13 Unsafe Shutdowns Life-span online 487 100 0 100 05/10/2022 21:01 100% OK
14 Media and Data Integrity Errors Pre-fail online 5 339 100 0 100 30/09/2022 12:44 100% Failing
15 Error Information Log Entries Pre-fail online 0 100 0 100 30/09/2022 12:44 100% OK
16 Warning Composite Temperature Time Life-span online 0 (0 minutes) 100 0 100 - 100% OK
17 Critical Composite Temperature Time Life-span online 0 (0 minutes) 100 0 100 - 100% OK
101 Temperature Sensor 1 Life-span online 51 (51 °C) 49 15 49 05/10/2022 22:22 40.0% OK
102 Temperature Sensor 2 Life-span online 76 (76 °C) 24 15 24 05/10/2022 22:22 10.6% OK
DRIVE ERROR LOG
error log is empty
Оценка 0
And second output of DriveDx for the 870 EVO :
Report Timestamp : 5 octobre 2022 22:38:16 UTC+2
Report Timestamp (ISO 8601 format) : 2022-10-05T22:38:16
Host Name : myMac
Time Since Boot : 1 day 00h 46m 25s
OS Name : macOS
OS Build : 21G115
  1. DRIVE 1 OF 1 ###
Overall Health Rating : AVERAGE 48.9%
Overall Performance Rating : GOOD 100%
Issues found : 3
Serial Number : xxxxxxxxxxxxxxx
WWN Id : 5 002538 f71201c25
Volumes : Stockage
Device Path : /dev/disk1
Model Family : Samsung SSD
Model : Samsung SSD 870 EVO 2TB
Form Factor : 2.5 inches
Firmware Version : SVT01B6Q
Drive Type : SSD
Power On Time : 7 042 hours (9 months 23 days 10 hours)
Power Cycles Count : 5 626
DEVICE CAPABILITIES
DriveDx Active Diagnostic Config : Samsung SSDs default config [ssd.samsung.common]
Physical Interconnect : SATA
Logical Protocol : SATA
Removable : no
Ejectable : no
ATA Version : ACS-4 T13/BSR INCITS 529 revision 5
SATA Version : SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
I/O Path : IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@17/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice
Attributes Data Structure Revision : 1
SMART Command Transport (SCT) flags : 0x3d
SCT Status supported : yes
SCT Feature Control supported : yes
SCT Data Table supported : yes
Error logging capabilities : 0x1
Self-tests supported : yes
Offline Data Collection capabilities : 0x53
Offline Data Collection status : 0x0
Auto Offline Data Collection flags : 0x0
[Drive State Flags ]: 0x6000100
[Last State Change Timestamp ]: 2022-10-04T22:12:51
[Last State Change Flags ]: 0x6000100
[Last State Change Diff Flags ]: 0x2000
Last Email Report Timestamp : 2022-10-04T22:12:51
Last Email Report Reason Flags : 0x6000100
Last Email Report State Change Flags : 0x2000
Data Read : 4 375 301 632 bytes (4.4 GB)
Data Written : 5 003 427 840 bytes (5.0 GB)
Data Read/Write Ratio : 0.87
Data Read/hour : 176.6 MB/hour
Data Write/hour : 202.0 MB/hour
Operations (Read) : 331 333
Read IOPS : 4 234
Operations (Write) : 66 215
Write IOPS : 846
Operations Read/Write Ratio : 5
Throughput per operation (Read) : 13.2 KB/Op
Throughput per operation (Write) : 75.6 KB/Op
Retries (Read) : 0
Retries (Write) : 0
Errors (Read) : 0
Errors (Write) : 0
PROBLEMS SUMMARY
Failing Indicators (life-span / pre-fail) : 2 (1 / 1)
Recently failed Self-tests (Short / Full) : 1 (0 / 1)
Time in Under temperature : 0 minutes
Time in Over temperature : 0 minutes
5 Retired Block Count 1 040 48.9% Failing
177 Wear Leveling Count 7 99.0% OK
179 Used Reserved Block Count Total 1 040 48.9% OK
181 Program Fail Count 0 100% OK
182 Erase Fail Count 0 100% OK
241 Total LBAs Written 9 916 669 207 (5.1 TB) 99.0% OK
Current Temperature : 30
Power Cycle Min Temperature : 19
Power Cycle Max Temperature : 28
Lifetime Min Temperature : 19
Lifetime Max Temperature : 55
Recommended Min Temperature : 0
Recommended Max Temperature : 70
Temperature Min Limit : 0
Temperature Max Limit : 70
5 Retired Block Count Pre-fail online 1 040 54 10 54 04/10/2022 22:12 48.9% Failing
9 Power On Hours Life-span online 7 042 98 0 98 05/10/2022 22:22 98.0% OK
12 Power Cycle Count Life-span online 5 626 94 0 94 05/10/2022 21:01 94.0% OK
177 Wear Leveling Count Pre-fail online 7 99 0 99 04/10/2022 22:12 99.0% OK
179 Used Reserved Block Count Total Pre-fail online 1 040 54 10 54 04/10/2022 22:12 48.9% OK
181 Program Fail Count Life-span online 0 100 10 100 - 100% OK
182 Erase Fail Count Life-span online 0 100 10 100 - 100% OK
183 Total Runtime Bad Block Count Pre-fail online 1 040 54 10 54 04/10/2022 22:12 48.9% OK
187 Flash Read Fail Count Life-span online 1 258 99 0 99 27/09/2022 21:02 99.0% Failing
190 Airflow Temperature Celsius Life-span online 30 70 30 45 05/10/2022 22:22 57.1% OK
195 Hardware ECC Recovered Life-span online 0x4EA 199 0 199 04/10/2022 22:12 99.5% OK
199 UDMA CRC Error Count Life-span online 0 100 0 100 - 100% OK
235 Power Recovery Count Life-span online 64 99 0 99 01/10/2022 23:10 99.0% OK
241 Total LBAs Written Life-span online 9 916 669 207 (5.1 TB) 99 0 99 05/10/2022 11:13 99.0% OK
DRIVE ERROR LOG
# | TIME OCCURRED | ERRORS | PRIOR COMMAND
5 6973 hours UNC READ LOG EXT
4 6973 hours UNKNOWN ERROR READ LOG EXT
3 6973 hours UNKNOWN ERROR READ LOG EXT
2 6973 hours UNKNOWN ERROR READ LOG EXT
1 6973 hours UNKNOWN ERROR READ FPDMA QUEUED
DRIVE SELF-TEST LOG
# | LIFETIME (H) | TEST TYPE | PROGRESS | STATUS | LBA of 1st error
1 7001 Short offline 100% Completed without error -
2 7001 Extended offline 10% Completed: read failure 90481528
3 7001 Extended offline 10% Completed: read failure 90481528
4 7001 Extended offline 10% Completed: read failure 90481528
5 7001 Extended offline 10% Completed: read failure 90481528
6 7001 Extended offline 10% Completed: read failure 90481528
7 7000 Extended offline 10% Completed: read failure 90481528
8 6999 Short offline 100% Completed without error -
9 6997 Extended offline 10% Completed: read failure 90481528
10 6996 Extended offline 10% Completed: read failure 90481528
11 6996 Short offline 100% Completed without error -
12 6966 Short offline 100% Completed without error -
13 4 Short offline 100% Completed without error -
DEVICE STATISTICS
[0x01] General Statistics (revision 1)
0x08 Lifetime Power-on Resets : 5 626
0x10 Power-on Hours : 7 042 hours
0x18 Logical Sectors Written : 9 916 669 207 (5.1 TB)
0x20 Number of Write Commands : 14 992 569
0x28 Logical Sectors Read : 11 135 129 380 (5.7 TB)
0x30 Number of Read Commands : 91 682 968
0x38 Date and Time TimeStamp : 1 253 000 ms
[0x04] General Errors Statistics (revision 1)
0x08 Number of Reported Uncorrectable Errors : 1 258
0x10 Resets Between Cmd Accept. and Compl. : 0
[0x05] Temperature Statistics (revision 1)
0x08 Current Temperature : 30 °C
0x20 Highest Temperature : 55 °C
0x28 Lowest Temperature : 19 °C
0x58 Specified Max Operating Temperature : 70 °C
[0x06] Transport Statistics (revision 1)
0x08 Number of Hardware Resets : 6 492
0x10 Number of ASR Events : 0
0x18 Number of Interface CRC Errors : 0
[0x07] Solid State Drive Statistics (revision 1)
0x08 Percentage Used Endurance Indicator : 0 %
Оценка 0
Добавьте свой ответ
BenedictFranz будет вечно благодарен.
Просмотр статистики:
За последние 24 час(ов): 1
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 300
