Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's Arm-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2337 or EMC 3598.
175вопросов Показать все
Grey stain spot on screen, not hot pixel?
Hello, I recently noticed a grey / brownish spot on my macbook air M1 2020 screen. At first I thought it was just dust stuck on or between the screen protector, but after removing the screen protector and cleaning the screen, the stain remains! Here's photos for reference, it's where the mouse is pointing at.
I suspect this is not hot pixel related because of the the shape and size, but I'm not entirely sure. If anyone have any ideas to how to remove this stain, as I can't afford a screen replacement, that would be gladly appreciated!
For more context, I use this macbook for work everyday and store it in a protective pouch.
Thank you so much in advance ❤️
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Agreed it’s a bug!
I would see if a short blast of compressed air can move it the the side. Be careful if you use a can of can’d air as you don’t want the liquid to squirt out as that will leave a stain.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thanks for the answer, I think the bug idea is most likely, I swear I saw it moved around by a few millimeters! Luckily my warranty is still up and Apple agreed to replace the screen, so I wouldn't have to mess around with it. Still sucks how this got past Apple's QA though...
из
Добавьте свой ответ
Duy Nguyen будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 75
