Repair information and guides for the minor refresh of the Late 2018 MacBook Air, with the same model number (A1932) and EMC number (3184). This model features a True Tone display and a slightly revised battery.
101вопросов Показать все
How can you visibly tell the difference between MacBook Air Retina scr
eens. (*!&*^#% 70 character limit) Anyways...
Let's say you took apart several MacBooks and your homies was distracting you (true story!) and thanks to their drunken ramblings you got all the parts mixed up now you have to reassemble them correctly. If you have these 4 MacBook Air screens on the table:
A1932, (2018)
A1932 (2019 true tone)
A2179
A2337
How can you tell which one is which?
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
Наиболее полезный ответ
Well. That’s a great question.
To be honest, this might be a bit tricky. The first thing I would check is if you can locate a different board number on the TCON board. I was hoping I had photos of my spare M1 TCON board on my phone to at least give you info for that, but I apparently do not. Those board numbers also may be identical, or may be the same across some models. But it’s the first thing that came to mind.
UPDATE: Now that I'm home, I dug out the board for the M1 machine. I am finding this may not be the best solution since the board number is actually underneath the sticker for one of the flex cables. However. I can confirm that the board number for the M1 (A2337) is 820-01891-02. Also don't worry, this board was already toast. It came out of a friend's machine whose (ex)boyfriend went "Bender Bending Rodriguez" on it and tore the whole display off the rest of the chassis.
I don't think I have the juice to rip my 2019 A1932 apart tonight for science, but maybe tomorrow. I actually use that so I would be a bit sad if it came to harm.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
rickcostel будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 5
За последние 30 дней: 12
За всё время: 177
