Huawei monitor with damaged backlight
Hi everyone,
I've recently got my hands on a Huawei Mateview 28" 4K monitor. It is in perfect working order, apart from a darkened strip across the left hand side of the panel. The panel still works fine and everything is visible, it's just darker in that strip.
Clearly this is a backlight failure - is there anything I can do to repair it? It appears to be IPS panel with a (WLED) backlight. I don't think the panel supports local dimming, but if it did it looks something like 1 of 28 zones is broken. Of course, I can't RMA it/etc (otherwise I wouldn't be here). I'm going to try opening it and see if it's anything trivial like a disconnected LED? Is there anything else I might try?
Cheers!
Это хороший вопрос?
3 Комментариев
Would be great to know how you managed to open this monitor up - don't see any apparent screws etc, therefore any advice you can offer would be appreciated.
из Andy Kennedy
Would be great to know how you managed to open this monitor up - don't see any apparent screws etc, therefore any advice you can offer would be appreciated. Also you may have a photos of huawei mateview 28 motherboard?
из Лусье Лашанс
@andykenned77084 have you found the way to open this monitor? may be you also have a photo of this monitor motherboard?
из Лусье Лашанс
