Black Conductive Pad under battery inside rear panel?
Where can you get these one side adhesive conductive copper / aluminium pads or tapes, do you know where ?
Это хороший вопрос?
Это хороший вопрос?
The copper helps dissipate heat, like a heatsink. When I work on iPod's, for example the touch 4g, I also add a dab of arctic silver paste since the paste is usually dried up.
You can find adhesive backed copper sheets, just cut to fit, google :
copper foil sheet
Был ли этот ответ полезен?
Thanks
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 275
Is this a necessary component?
из Brad
I think so, because when the battery charges, it heats up. The pad takes the heat and via the body transfers it out of the case.....
из Arnoud
do you mean on back of motherboard or on inside of rear case???
из pollytintop
Inside of rear case behind battery....
из Arnoud
Slide 30 in changing the rear case gives a good view.
из Arnoud
Показать 2 больше комментариев
