CPU light is on on motherboard, display goes out.
On my desktop computer, the CPU light on the motherboard is often on and there is no display on the screen.While the fans keep spinning, it doesn't get fixed unless I reset it.I searched and took it to repair, they couldn't find the problem, I would be glad if you could help.
Это хороший вопрос?
7 Комментариев
https://www.asus.com/us/support/FAQ/1042...
problems Ur CPU one of the pins are broken most likely
из hay yew
or improper installed
из hay yew
Normally there is no problem, sometimes it happens.
из Fatih Dogan
@fatihsir what model is your motherboard? what model is your power supply?
из oldturkey03
Msı b-450m pro-vdh plus
из Fatih Dogan
Показать 2 больше комментариев
