Not able to lift the call
I get the vibration but not able to see the incoming call details and not able to lift the call
Это хороший вопрос?
Это хороший вопрос?
Could be just a configuration issue; on pre-Android Pie (Android 9) phones, which should be your case, here's what you should check:
go to Settings menu, open Apps, then Notifications, make sure the switch is flipped on.
Also make sure Incoming calls permission is on and importance is set to Urgent
Reference tutorial here.
If this doesn't solve it, there could be something interfering with the proximity sensor's functionality. At this link you'll find some useful tips give them a try, for a quick sensor test you can also go with the built-in diagnostic tool, should be accessible by simply dialing the code ##0588#*#*.
Был ли этот ответ полезен?
Not support software
Maya, if you're looking for help, you'll need to give us a lot more to go on; the better your description of the problem you're having, the better your answers will be.
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 115
