Флагманская и самая дорогая модель смартфона от Apple 2019 года, была выпущена 20 сентября и стала логическим продолжением линейки iPhone XS Max. Новое устройство имеет 6,5-дюймовый OLED-дисплей, тройную основную камеру и сильно увеличенное автономное время работы от аккумулятора.
Why won't my phone turn on after replacing screen?
I replaced the front screen, and it won't turn on. Could it be the charging port is damaged? Could it be the battery? Could it be the motherboard? I tested two screens, so I know it is not the screens.
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Out of curiosity, was replacing the screen the first thing you did to try and diagnose the problem of not turning on, or was there another reason and the phone was turning on previously? How did it start; did anything change recently such as an IOS update, or any kind of damage like being dropped, getting wet, etc.?
As @tomchai mentioned, there are unfortunately a lot of different reasons why a phone doesn't turn on. Do you get any kind of indication such as a chime or vibration when you plug in a charger? You've tried different chargers and cables, right?
Go through this troubleshooting guide and see if anything there helps. If not, come on back and add the information on what you find to your question and we'll see what we can do to help.
iPhone Won't Turn On - iFixit
Good luck; let us know how it goes!
Был ли этот ответ полезен?
Счет 2
Could be anything, you swap the parts to find out.
Счет 1
i change the screen, first time the new screen can turn on, but when I restarted it again, it cann't work, but I can sure the battery is ok, bez the scilent button is work well.
Счет 0
Добавьте свой ответ
B P буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 294
