Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's Arm-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2337 or EMC 3598.
175вопросов Показать все
MacBook is boot looping
The mac is completely unresponsive even the power button doesn’t work when its off so i plug the power adapter in for it to start up and when it does turn on the apple logo shows up and the loading bar shows up and then it shuts down and does it all over again, if i hold the power button it says keep holding for recovery options and then says loading recovery options then after a bit it shuts down again and boots back up and it is a never ending cycle, it wont shut down unless you unplug the battery. This is really a brain twister and has me scratching my head for 3 days now, any advice would be greatly appreciated.
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
DFU reinstall the board firmware then try recovery again. If not working, something on the board is busted.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
that is the link I used to be able to go into DFU mode and it gives a quick rundown on what to do, best of luck to anyone that needs to do this in the future
https://www.youtube.com/watch?v=i5xmA3lD...
из
Добавьте свой ответ
mostintin08 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 12
За всё время: 241
