iPhone 7 plus был выпущен 22 сентября 2017 года и увидел свет в качестве двух модификаций: A1863, A1905. Поставлялся с двумя различными модулями мобильной связи: GSM или CDMA, а также с 64 Гб или 256 Гб встроенного хранилища. Цвет корпуса можно было приобрести золотой, серебристый или Space Gray.
How can I bypass the locked to owner
My Iphone is locked to owner and the previous owner is not available, is there a way to bypass it?
Это хороший вопрос?
Счет 11
1 Комментарий
My iPhone 11 pro is lock by the owner and I don't know the owner because it's a second hand iPhone, how can you help me please?
из
Добавить комментарий
5 Ответов
Выбранное решение
Hi
Sorry but this isn’t really possible unless you do some stuff under the radar that doesn’t even fully unlock it
Your best bet is probably to contact the company or person that you bought it from any see about getting your money back as trying to unlock something from iCloud is not fun and rarely works
Hopefully this helps
Any questions please ask
Был ли этот ответ полезен?
Счет 6
2 Комментариев:
how do I do it
из
So when is going to open bypass
из
short answer is no.
the icloud-to-phone association lives on Apple's servers and the only way to break it is to to remove it with the icloud account name and password either on the phone, appleid.apple.com or www.icloud.com.
doing any of the erase/reset functions will not remove it.
itunes or 3utools will not remove it.
you may see software solutions or services that say they can remove it, but they mostly involve jailbreaking the phone and doing a "workaround", but any time you power-cycle the phone, perform any sort of reset or update IOS, you will have to apply the workaround again. i have no idea how effective they are, but i don't do jailbreaks, so i wouldn't consider nay of these, plus most of them require a subscription.
anyone offering a service to remove it is probably a scam.
that said, depending on the model and configuration, icloud locked phones sell on ebay all the time.
Счет 2
You may be able to fully reset the phone which might remove the lock.
I use the 3U Tools program which can put your phone in either the reset mode or completely wipe it.
Hope this helps.
Счет 1
1 Комментарий:
doing an anti-recovery flash with 3uTools will update IOS, reset all settings, clear any passcode and return the phone to OOTB condition, but it WILL NOT remove the icloud account.
из
If you know your iPhone’s screen passcode and see the “Unlock with Passcode” option on the Locked to Owner(iCloud Activation Lock) screen, you can tap it and choose “Enter Device Passcode” to remove the iCloud lock.
If that option isn’t available, but you have enough proof that you’re the legitimate owner of the device, you can try reaching out to Apple Support for assistance.
Счет 0
I saw some tutorials on YouTube that said it can be unlocked using tools like TunesKit iPhone Unlocker. Many youtubers showed the unlocking process, but I don't know if it's really possible.
Счет 0
Добавьте свой ответ
Bonga Peter буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 19
За последние 7 дней: 150
За последние 30 дней: 764
За всё время: 9,089
