@jay99 for now I'd go and check a few things according to the general 7000 series SM. I would use the troubleshooting for the "Engine runs but misses" troubleshooting
Engine Runs But Misses
● Carburetor adjusted incorrectly.
● Engine overheated.
● Faulty spark plug(s).
● Ignition module(s) faulty or improperly gapped.
● Incorrect crankshaft position sensor air gap.
● Interlock switch is engaged or faulty.
● Loose wires or connections that intermittently ground ignition kill circuit.
● Quality of fuel (dirt, water, stale, mixture).
● Spark plug lead(s) disconnected.
● Spark plug lead boot loose on plug.
● Spark plug lead loose.
Choose things that could have happened by a bit of impact. See if this manual Kohler 7000 SM will help you to narrow it down
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
4 Комментариев
@jay99 you have a complete engine number? I wonder if the "timing" got knocked out of whack
из oldturkey03
@jay99 One possibility is the timing being off, like @oldturkey03 said. That is rarer though, because hitting a root with a zero turn (I’m assuming that’s what you have) shouldn’t be anywhere near enough to knock timing off. Had it been a walk behind (push) mower, absolutely, because those have the blade directly on the engine axle. (That’s why they use flywheel keys.)
A complete engine number and mower model would help.
из Geir Ove Andersen
It says kt730
из Jay
@jay99 the attached SM in the answer will cover your model
из oldturkey03
