Выпущенный 16 сентября, "меньший" флагманский смартфон Apple оснащен 6,1-дюймовым OLED-дисплеем ProMotion, трехлинзовой системой задней камеры, 5G и новым дизайном "Динамического острова" вокруг фронтальной камеры и верхних датчиков. Преемник iPhone 13 Pro.
22вопросов Показать все
In back side one white spot
I’m recently buy this phone dark purple I phone 14pro but there is one white spot on back side. I’m asking to shoe they said to contact in IFIX. I’m buy 3 phone at time but 2 phone is colour but mine defective. Apple giving this type service to the customer I’m not happy with this.
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi Mahendra,
If I'm reading your question correctly, you just bought a new iPhone 14 Pro and there's a defect in the color on the back glass, is that right?
At this point you have three options.
  1. Return the phone for a replacement. Given that this is the latest model and should still be under warranty, you should be able to get it replaced.
  2. Replace the back glass. This is an extremely difficult repair, as the adhesive used on the rear glass of most iPhones is extremely strong, so it requires a heat gun or laser to loosen the glue enough to be able to chip the glass out of the frame.
  3. Replace the entire rear chassis. This saves you the difficulty of removing the rear glass, but that gets made up for by the fact that you have to transfer every single component inside the phone to the new housing.
Unfortunately, your phone is so new that no guides are available for replacing the rear glass or the chassis; you may be able to find YouTube videos, but none of the regular repair sites I'm aware of has any information on the 14 Pro.
I'd strongly suggest contacting either the seller or Apple itself to see about a warranty replacement.
Был ли этот ответ полезен?
Оценка 1
i have same issue.
any update my freind?
Оценка 0
2 Комментариев:
what issue do you have, screen or back glass ?
из
purple back of my 14 promax has one small white spot.
из
Добавьте свой ответ
Mahendra Kumavat будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 19
За всё время: 1,279
