I cant get any spark , I replaced my cap n rotor notsure if its my co
No spark at all i replaced the cap n rotor im not sure if its the coil or the ignition module?
Это хороший вопрос?
Это хороший вопрос?
I know it's a different make/model than my own vehicle, but when I couldn't get any spark it was the icm for me. Located inside the distributor. I posted a pic of yours so you can see where it should be.
Был ли этот ответ полезен?
I think there are several common-ish causes for this symptom. Without additional details of what all has been tried,. here are a few thoughts and some supporting links:
-bad key code
-Bad ignition coil(s)
-bad plug(s)
-damaged cam position sensor
-broken timing belt
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 42
1 Комментарий
mattcannon48 what engine size does your Accord have?
из oldturkey03
