Replacing the volume control wheel potentiometer
I'd like to replace the volume control potentiometer in my headphones. Does anyone know the parameters of the required replacement part?
Is it 10 K-Ohm like below? Is there someone who did this successfully here?
Это хороший вопрос?
Оценка
Are you wanting to replace the pot because it is noisy and crackles when you turn it? I had the same problem. I got some DeoxIT contact cleaner and gave the wheel a good spray (in the out of doors!).
The crackle went away and never returned in over a year
из Charles Dill
Plus one one this recommendation - alternatively you may use WD40 Contact Cleaner - helped me out with cracking pots throughout the years, but please don’t confuse it with regular WD40
из in_sympathy
