A phone made by Samsung running Android 6.0 1.4GHz Octo-Core Qualcomm Snapdragon 430 SoC 1280x720p 5" Display 16GB of onboard storage (expandable)
5вопросов Показать все
The process com.android.phone has stopped
This error keeps coming up when I press OK it comes back constantly even after clearing data for the phone app how do I fix this without reseting it?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
If you see the error message “Unfortunately, it has stopped
process.com.android.phone
or unfortunately stop
com.android.phone
Process after installing ROM
If you are new or update your firmware, there are actually several ways to fix it
The error message is triggered by phone or SIM toolkit app
So, if you are constantly getting the “Unfortunately, the process com.android.phone has stopped” error.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Solution #1: Disable automatic date and time
This simple setting change can help you remove the error message for good. To change this, go to Settings from the Home screen, then tap
из
Second solution: Clear data and cache
Third solution: Clear data and cache
Boot the device in Safe Mode
из
Добавьте свой ответ
80stechkid будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 96
