Why does my a/c shoot out threw all air vents?
My 2010 Honda accord lx a/c will only shoot air to the feet even though if it’s on front windshield or if I have click too shoot air at my face it only shoot threw out the feet area
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (3)
Наиболее полезный ответ
gonzalezcarlos.99 could be a failed blend door actuator or AIR MIX CONTROL MOTOR. Check on something like this video to work on it. Here is the complete HVAC module from the service manual. Page 9 shows you how to run the self-diagnostics for your HVAC control unit. See if that gives you something else. 2010 Honda Accord HVAC
Был ли этот ответ полезен?
Оценка 2
Since You indicate that you have an LX model, I would assume that you don't have a climate control system (meaning split controls for driver and front passenger area temperature control.)
That said, you can run a check on your system from the controls:
  1. Turn the ignition switch to Lock (0) and then back to ON (II)
  2. Set the fan control dial to OFF, the Temperature Control dial to Max Cool and select the VENT mode.
  3. Press and hold the RECIRCULATION button, then within 10 seconds press and release the REAR WINDOW DEFOGGER / MIRROR DEFOGGER button five times. Release the RECIRCULATION button; the recirculation indicator blinks two times, then the self-diagnosis begins.
NOTE:
  • The blower motor will run at various speeds in the self-diagnostic mode
  • Once the sequence is finished, the recirculation indicator blinks and the blinks indicate the Diagnostic Trouble Code (DTC) number. If there are multiple DTCs the indicator blinks each DTC in sequence from the lowest DTC number to the highest
  • The indicator pauses 3 seconds, then repeats the DTC blink sequence.
  • If no DTCs found, the indicator does not blink.
I suspect thaat the DTC will show 10 or 11 blinks, since you have a '10 Accord LX (assuming automatic transmission) and per the service manual:
  • 10 blinks indicates open or short in the mode control motor circuit
  • 11 Blinks indicates a problem in the mode control motor circuit.
I don't have a simple way to display the pages in the Honda Service Manual for your car, but if you want to comment as to results if you run the diagnostic, I can maybe add to the answer.
Оценка 1
1 Комментарий:
My 2010 accord is blinking 10x what should my next step be?
из
Mode doors can be controlled manually by dial/knob, cable and linkages or operated by servo motor. You'll have to look around the hvac box from driver's and passenger side to determine configuration. Removing the hvac control panel may help too.
Оценка 0
Добавьте свой ответ
gonzalezcarlos.99 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 705
