Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's Arm-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2337 or EMC 3598.
175вопросов Показать все
Possibility to upgrade SSD and RAM? (MacBook Air 13")
My Son requires a laptop for College.. I would like to get him a MAC,
Can you Please inform me as to the latest version which allows for the updating of Memory SSD and RAM (Should they be required at some point)
Thanks in Advance
Это хороший вопрос?
Оценка 1
2 Комментариев
What kind of programs will your son be running for college?
из
He is studying Economics. So there are a few Mathematical programs that are provided by the Uni (In German) but I'm not sure of there names. But what he is looking for is something with a bit of Stability, longevity, which is light and not too large.
из
Добавить комментарий
1 ответ
Выбранное решение
Sadly none of the current generations of MacBook systems offer future upgrading. What you buy is it!
Now while that might be a turn off. As long as your son has a cellphone he can tether his system just about anywhere he can get a cell signal, in the dorm a WiFI or even a wired Ethernet network connection. With that accessing cloud based storage is possible! The next option is just connecting an external drive or two to hold stuff like his music or other media, or the boring 😏 class work and any research needed for the required papers. Besides, he will want to backup this stuff in some form just in case, as laptops sprout legs and scamper off!
16GB should serve his needs.
Please get the extended service coverage and enable FindMy services with his Apple Gear.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Wow. thank you so much, for your prompt and concise reply.... Greatly appreciated... Thank you so Much...
из
Добавьте свой ответ
Dusty Rhodes будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 225
