The Sega Genesis (also known as the Mega Drive) is Sega's most successful video game console to this date.
37вопросов Показать все
Power switch replacement, is it easy?
so i have two Genesis model 1 consoles and one has a very stiff power switch and the other console doesn’t work but the power switch is very easy to slide. So I want to swap the power slide switch but I can’t find any videos about this. However, I’ve seen a photo of one that was removed but the guy that took it off said he broke it and in the photo there was a spring beside the switch. I guess I just want to know if I desolder the switch, is it going to just fall apart on me?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
So I no longer need to worry about swapping the power slider switches, I bought some lithium grease and worked it into the slider switch and now it slides like butter.
Был ли этот ответ полезен?
Оценка 1
Наиболее полезный ответ
It could be a build up of dirt causing it to be stiff. I’d try cleaning it first. Very old machine so greasy fingers over time could of clogged it up.
Оценка 2
1 Комментарий:
Yeah I used some contact cleaner and it helped a bit but still too stiff when the case is put together. I’m going to try some lithium grease first (being delivered today) and see if that helps. But if not, I wanna try and swap them.
из
Добавьте свой ответ
Kevin F будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 37
За всё время: 465
