The Motorola G5s Plus can be identified by its model number: XT1804 (varies based on country). It is an updated version of the 5th generation of Motorola’s Moto G series. Some distinguishing features of this device are its metal unibody design, improved front and rear cameras, and bigger battery.
18вопросов Показать все
How to repair my micro usb port?
Can you please guide me through how to replace my micro usb port? for some reason the charger doesn't fit anymore.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
George Kovac, Did anything happen to the phone, like was it dropped or maybe it was connected to the charger and the cable was “yanked”?
I’m not too familiar with this device, but you could probably source a new charging (dock) assembly for the phone, for not too much money. The other solution is to desolder the one on the phone now, and solder on a new one. NOTE! This requires micro soldering and skills far beyond normal soldering (and equipment). I wouldn’t attempt it for a first repair?
When going into micro soldering, you need to practice a LOT in order to get the hang of it. Getting fex a bunch of iCloud locked iPhone boards and practice on them. Bonus is that you can use the boards as donor boards for later.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
@geirandersen in typical Motorola fashion, it is soldered directly to the mainboard. Motorola didn't use daughterboard. The only way to fix it is by soldering a new port in place.
из
@oldturkey03 Figures; I haven’t worked on that level on a Motorola since the flip-phone crazy days.. Manufacturers really know how to endear themselves to us repair techs 🤨
из
@geirandersen they sure do don't they. Not a bad job but a PITA for anybody that does not have the tools or not developed the skills yet.
из
Добавьте свой ответ
George Kovac будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 11
За всё время: 47
