An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
163вопросов Показать все
Big problem with my Gameboy Advance SP
I have a GBASP and i haven’t used it for about a year.
I’m 11 and got it back in 2021 and it came with Pokémon FireRed(my favorite) and Pokémon Sapphire. But when i loaded both in. At some point it would glitch out. I can’t even progress without my Charmander turning into a “Bad egg” or the game freezing and messing up textures or the speakers making a horrible noise. The pins look fine. Note that we got this from Mercari, a second-hand site. It has a few scratches and the backlight and screen are fine. Please help as I want to use it!
Update (12/18/2022)
Here are the images:
Это хороший вопрос?
Оценка 3
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi
Have you checked the battery’s in the cartridges?
These battery’s in them are getting pretty old so might be worth checking
If you haven’t here’s a battery replacement video
https://m.youtube.com/watch?v=1piXd3ffwu...
Был ли этот ответ полезен?
Оценка 3
12 Комментариев:
I have opened it and it looks clean but i dont have(or can afford) a new battery :(
из
@chriswastaken
I see
If you want we can check to see if the battery is the issue as it could be a simple fix it not:-)
из
Alright! I’ll update you on it when i get the battery out
из
@chriswastaken
Sounds like a plan:-)
из
Heyo! So im gonna add some images if i can in a minute so hold on
из
Показать 7 больше комментариев
Добавьте свой ответ
Chris будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 16
За всё время: 307
