A consumer grade laptop which features a 15.6'' HD LCD screen, Bluetooth, and a fully functional touchpad.
Replacement battery discharge rate?
I just replace the battery (PX03XL) and am wondering what I should expect for battery life. I realize it is an old laptop, approx. 9 yrs old, but I only seem to get about 3 to 3.5 hours of combined use before needing a recharge. Usage is mostly e-mail, web browsing and idle time. Keyboard backlight is off and display is approximately 70% brightness. Is my expectation for 6 to 7 hours unrealistic? Is 3 to 3.5 hours about right?
Thank you.
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Выбранное решение
What are the capacity of the new and old battery? Get HWInfo and monitor the average power draw over a full charge-discharge cycle and then compare it to the rated capacity to calculate the expected runtime.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
Yikes way too complicated! How would I monitor power draw.
But thanks for responding.
из
@Dave B theres an application called hardwareinfo which shows the current state of all the things inside your laptop including power draw. aside from that i think 3-4 hours of battery life is a reasonable expectation for a 9 year old laptop with a replaced battery.
из
Camden, I like your "aside" comment. Thank you!
из
Добавьте свой ответ
Dave B будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 7
За последние 30 дней: 12
За всё время: 146
