Смартфон был выпущен 22 сентября 2017 года в двух модификациях: A1864, A1897, доступный GSM или CDMA модулями. Встроенное хранилище есть на 64 Гб или на 256. iPhone 8 Plus увидел свет в трех оттенках корпуса: золотом, серебристом и Space Gray.
Error reading LCD data
I am trying to change LCD screen on my iPhone 8+ So i recently spend more than 100$ to buy the latest Qianli iCopy + 2.2 version. But unfortunately when i try to read data from my original and replacement LCD screen the quickly show "Reading Screen" less than fraction of a second and jumps back to the main menu. I then tried reading and writing it through the PC software (by copying the board number), but unfortunately got the following errors: " Data reading failure:
  1. communication line/connection error or
  2. Short circuit or disconnected"
Please see the attached image. However, the iPhone XR LCD reads just fine.
Have upgraded the device firmware. Also similiar problem with someone here:
https://www.reddit.com/r/mobilerepair/co...
Appreciate help. Thanks.
Это хороший вопрос?
Счет 1
Добавить комментарий
4 Ответов
Наиболее полезный ответ
I'm not sure I have an answer to your issue, but perhaps some of my experience with my first attempt at using the iCopy for an iPhone X will give you some ideas.
First off, I never had any issue reading the serial number from the screen, but could not for the life of me manage to program the screen with the correct number. My first discovery is that the Qian Li software does not give you the correct number you need to program into the screen when you hook up the iPhone directly to your computer. All you get is the serial number of the phone, which doesn't help.
I ended up downloading both 3uTools and the JCIDRepair software, both of which reported the number I needed from the phone. At some point with all the plugging and unplugging between the phone and the iCopy, my new replacement screen stopped powering up. I discovered the connector had broken and looking closely at the connector on the iCopy board, it seemed to have a pin that was broken too. So I'm now at a standstill while waiting for my replacement iCopy board.
At any rate, check the iPhone 8 plus connector on the iCopy board carefully; they don't seem to be the highest quality and mine is definitely broken. The upshot is that I can read the data fine, but cannot program even an original iPhone screen currently. Hopefully a replacement board will solve that.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
I have used my iCopy 2.2 on more screens than I can count, and never had a problem. They’ve all been read and written without fault.
I do however share @dadibrokeit’s concern about the connectors! Prior to putting mine to use I did inspect the connectors as best I could, and determined that I should take care when connecting and disconnecting screens/batteries/etc.
из
Remove the black circuit board from the reader then remove the cellophane. Put the board back on and try again.
Счет 1
1 Комментарий:
Hello. Thanks for ur reply. The external cellophane is just for dust/water protection. There is nothing below the panel blocking it. But I still removed whatever cellophane was left. Still got the same error. However, note that I am able to read and write date from iPhone XR display just fine with this same board.
https://serving.photos.photobox.com/0698...
https://serving.photos.photobox.com/1113...
из
Hello .. thanks for the answer. I am working on sourcing a replacement board to try if it works. Meanwhile when i connect the battery repair board to program the battery, i notice the following :
The battery board detects the battery on all iphone models i tested (8+, XR) and I am able to change the battery capacity and percentage from qianli (both from machine and PC). So for instance if i program the iPhone XR battery capacity from 70% to 90%, qianli does it with by successfully write message, I can confirm this by removing and re-connecting the battery to the connector board, and qianli reads and shows the battery capacity with new updated changed cpacity as 90% on its display screen. However, when I insert the battery back and connect the phone, it shows the same old 70% "Service" status in the maximum capacity.
I tried doing many power cycle (discharging and fully charging) my phone many times, also tried installing IOS operating system several times but it still shows the old battery capacity. It looks like in the new ios releases Apple did something so that the ios reports only the old battery capacity even after someone changes it. Any solution to this?
Счет 0
I have had this problem and have discovered it is cheap screens cannot be programmed. When I purchase a premium or supreme screen I do not have a problem. Also you must have the camera installed before you program the new screen. (Camera not required on old screen)
So if you are buying from iFixit they probably sell higher quality screens. If you are having this problem with a cheap screen…chances are you need to get better quality. 😬 sorry for the bad news but it isn’t the qianli programmer.
Счет 0
Добавьте свой ответ
Gtm 18 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 890
