Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2188вопросов Показать все
wifi not working - preliminary causes
i'm considering procuring an iphone 7 with the issue of "Wifi not working, won't connect to a wap/hotspot". i'm taking a flyer on it. if it's well and truly unworkable, i can gut it for parts. however (as long as the icloud is off) i always take a shot at trying to rehab/resurrect a phone with issues.
if all you know is "the phone works, but wifi doesn't" what are the chances it's an antenna or some sort of non-motherboard component that needs to be swapped out vs something on the motherboard? i will do component level swaps, but i have neither the tools nor skills to do microsoldering or chip level repairs.
first thing i'll likely do is pull the motherboard and drop it into a iphone 7 back housing (with all known good parts) and crank it up. i'm just curious about what expectations i should have regarding this wifi problem. for example, if it's 100% a motherboard issue, i might give let it go, but if there's a (fair to good) chance that it's something else, it might be worth a shot.
insight and experiences would be most appreciated.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
If the Wi-Fi is greyed out in the settings app it will defiantly be a board issue which usually results in having to change or re-ball the Wi-Fi IC. If it is not greyed out it could be a signal problem if this is the case installing the logic board into a known good housing would be the best way to check.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
at the moment, i don't have that information. all i have a report that the "wifi doesn't work"
из
Board issue.
из
Добавьте свой ответ
B C будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 34
