Sony DSC-RX10M3 - Released 2016, 600mm Zoom
11вопросов Показать все
Advice on Main board replacement
problem 1: need to replace my broken one inside the camera
Problem 2: camera repair centers say authorized Sony repair centers wont accept used parts, such as the used main board I have to put in the camera
what do you think? Do I absolutely need to buy a new part?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Evan Girard no you do not. Used parts are okay to install, just not through an authorized service centers. They do not accept your used parts because they could not guarantee their repair and would not make any money of you. You can most certainly install most parts yourself.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Where did you get the main board from? I need to replace mine but there seems to be several options ranging from cheap to expensive
из
Добавьте свой ответ
Evan Girard будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 133
