Part of Google's third generation of Pixel phones, the 3a is a budget-minded option with the same camera as Google's flagships. Available in Clearly White, Just Black, or Purple-ish. Released May 2019.
70вопросов Показать все
Dropped Pixel 3a, No Cell Service Signal
Dropped my phone. Everything is fine, except the signal bars just display a "!" and quick-settings drop-down shows "No service"
Restarting the phone and reinserting the SIM had no effect.
What to do? Is there a cell antenna I can detach and re-attach?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Fixed it by:
Using heat to open up the phone, taking the screen off, accessing the board.
Disconnecting and reconnecting the little flat-top connectors near the center of the phone. (Didn't touch the coaxials at all surprisingly).
And that's it!
Был ли этот ответ полезен?
Оценка 0
maybe the antennas were damaged when your phone was dropped (not sure if this is possible, so lets see if anyone else can help you with a better guess)
Оценка 0
Добавьте свой ответ
Seymor Butz будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 6
За последние 30 дней: 11
За всё время: 148
