Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2188вопросов Показать все
Touch ID of iPhone 7 not working after screen replacement
I installed a screen including the home button from a different iPhone 7. After a successful boot, an error message says "Touch ID not working".
Is this Apple, trying to prevent their devices from being repaired or did I mess up the connectors?
Это хороший вопрос?
Оценка 0
1 Комментарий
So your original home button was damaged? If not then swap it back over to the phone and it should work properly.
из
Добавить комментарий
2 Ответов
Выбранное решение
the 6s was the last generation of phone where you could use an apple button from one phone in another, but you would lose Touch ID capability. with the 7 (and going forward) the only apple button that will work in a phone is the one that came with it from the factory. unless you go to apple and pay through the nose for an official home button replacement, your only option is to get a good quality (JC type) 3rd party home button from a source like injured gadgets or ifixit. it will give you home button functionality, but no Touch ID.
or you could just put the original home button into the new screen, if that's an option
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Thank you for the detailed solution. Fortunately, the homebutton was intact and I was able to switch them. Works 👍
Do you know If there are any other components which are paired with the mainboard, as I plan to switch out the mainboard on another iPhone 7 as well
из
@sebi, just the home button, everything else should be fine.
из
Наиболее полезный ответ
@sebi108, Yes, the TouchID functionality of the Home button is serialized to the logic board. Only the original Home button will work with your phone, unless it’s replaced by Apple and they pair the new Home button.
Оценка 3
Добавьте свой ответ
sebi будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 37
