What part of the circuit is responsible for this short?
I have this water damaged switch, I cleaned all corrosion with toothbrush and isopropyl alcohol, there doesn’t seem to be any shorts any where else but here and I’m not sure what chip or part of the board is causing this. Any help would be great
Red = shorted to ground
Blue = no reaction to ground
(Bottom of board under heat sink)
Это хороший вопрос?
2 Комментариев
Hi
When you apply power to the board does that area get hot or warm in any way?
If it does :with power on the board apply a small amount of isopropyl alcohol to see where it evaporates first
Where it evaporates first is the component with the issue
из HelloMacOS
they aren't shorted to ground they are low resistance rails
из daniel
