Repair information and guides for the minor refresh of the Late 2018 MacBook Air, with the same model number (A1932) and EMC number (3184). This model features a True Tone display and a slightly revised battery.
101вопросов Показать все
How hard is it to replace a single key on a keyboard?
I recently got a MacBook that has a single button missing. Specifically the “up” arrow button. If you can point me to a good replacement video and a source to purchase a new one I would be grateful
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
While I can aim you to a source for the key cap $$ how about free instead? Apple has a special extended repair program for the Butterfly keyboard Keyboard Service Program for MacBook, MacBook Air, and MacBook Pro
If you can find the key cap that would help, but they should still fix it just say you put in your pocket and your mate washed the cloths before you could save it!
At least that way you don’t even need to fiddle with it.
Был ли этот ответ полезен?
Оценка 1
4 Комментариев:
Well doesn’t Apple charge you like $100 to fix things? I got this MacBook second hand so I don’t have Apple Card or anything
из
@balakae - Apple has a special extended Warranty on this system it will cost you all of nothing! Zip and every other word which means FREE!! Click on the blue URL link I posted. If they give you a hard time let me know.
из
I appreciate the help and happy new year! I have reached out to them and they said I would need to bring it to a store 100 miles away or ship it to them. Then it will be up to the technicians discretion if it is covered or not. They can’t tell me before hand and if it’s covered so basically i assume I’ll be stuck with the bill if I get the wrong technician?
из
@balakae - OK, it’s a pain to get to the Apple Store, shipping it is not something I recommend for such a minor issue.
Here’s the source for the Key Caps MacBook Air Key Caps
из
Добавьте свой ответ
Blake будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 65
