Why is my wifi and bluetooth not working
Why is my wifi and bluetooth not working Why is my wifi and bluetooth not working
Это хороший вопрос?
Это хороший вопрос?
There could be several reasons why your WiFi and Bluetooth are not working on your Samsung Galaxy A10s. Here are a few things you can try to troubleshoot the issue:
Был ли этот ответ полезен?
I did factory reset but it still doesnt wrk
Hi I did all but didn't work
After the last Samsung update my wifi and Bluetooth isn't working as well
Same for me, bluetooth and wifi can't be on. when I tried to open it it'll become off again.
Same here to me
الخلل في ايسي بلوتوث والحل استبدال الايسي او تسخينه راح يرجع الجهاز طبيعي
Google translate:
The fault is in the bluetooth eSee, and the solution is to replace the eSee or heat it up, and the device will return to normal
how to replace the esee or heat it up?
Oh my gosh I did everything but still won't connect I'll just chill here and wait for the answer
I am facing the same problem. My Wifi and Bluetooth is no longer working. Is there any Samsung Technician ca help me fix this problem? Thankyou.
I am also facing this issues wifi and Bluetooth devices is not working plz tell me solve the solution plz
Even if I refractory doesn't work
If your WiFi and bluetooth not working it is because of Ic problem you have to change it
I did perform factory reset but still the same. Help me out pls
How can we replace Or heat it where it is inside the phone?
If you have WhatsApp installed. Try cleaning WhatsApp data or uninstall WhatsApp. It works fine for me. A10S
It's a hardware issue. The phone's IC has a problem that's why the Bluetooth n WiFi don't work. The technician will demand approximately R250 to R350 to fix it.
No hardware issue this is new update issue.
Not an update issue. My phone has not received an update in years because it an old phone (Galaxy J5 prime). So it is a hardware issue-
My Samsung a10s have the same problem
turn on bluetooth to connect to nearby devices
Still my phone doesn't want to open
Reset your Wi-Fi router. The location of the reset button depends on what Wi-Fi router you are using but every Wi-Fi router has one.
Thank you, Anthony, but this is not a solution to problem.
Well I will suggest to do the software update or system updated of your phone. Sometime outdated software version can also cause these kind of issue as well.
You can't update phone without WiFi
Even if I restart don't enable and not op6
I did restart but still is not working
Its hardware issue my 2 devices one got resolved heating ic and second one had replaced ic MT6631N
WiFi not opening
Since the problem occurred with all users of this version of Samsung, this means that its function was stopped in the latest Samsung update.
My wife and bluetooth are not working on my phone my phone is Samsung A10s
Bluetooth 11
WiFi and Bluetooth connection is not working
I have an S20+ and a WiFi 6 home network. I'm running the May 2023 update to OneUI 5.1.
Suddenly last night I was unable to connect to my home WiFi network. WiFi worked fine for all my other devices. I did lots of Google searches.... After trying all the obvious simple things (toggling Airplane Mode, Rebooting the phone, etc.), I looked in the S20+ Settings / Developer Options this morning and found "WiFi non-persistent MAC randomization" and turned it ON. WiFi almost instantly started working again on the phone.
I hope this helps others.
Cheers,
Scott.
My wifi and Bluetooth malfunctioning since last 2 months
Why my wife and bluetooth not working on network
My bluetooth and wife are not working my phone is Samsung A10s
Me 2 my Samsung A10s is not working
Bluetooth, WiFi and hotshot won't connect
My wifi and bluetooth not working
My Wifi and Bluetooth is not working in Samsung s20+ and developer option is also turned off
My wifi & bluetooth not working, I have samsung Fold 3… .I got sick of samsung, Im going to buy Honor magic v3
Wifi Bluetooth not working why problem factory already but not solve
f your Wi-Fi and Bluetooth aren't working, start by restarting your device and router, and check for simple issues like interference or drivers being outdated. If those don't work, try resetting your network settings, which will erase saved Wi-Fi passwords and Bluetooth pairings but can resolve connection problems. For persistent issues, consider updating your system or, as a last resort, performing a factory reset.
За последние 24 часов: 27
За последние 7 дней: 112
За последние 30 дней: 658
За всё время: 77,437
29 Комментариев
Has the phone been dropped or damaged at all?
из [deleted]
I did factory reset but still not working
из Luvland Unique
I went in my hardware but my wifi and bluetooth are not listed in and its says unavoidable
What must I do
из Nicodemus Hangusu
I'm having the same issue on my Samsung Galaxy Note 20 Ultra. After the new update, they both stopped working.
из Amado Guerrero
Check (verify) the time zone on your phone. I had this problem On the last update and resetting the TIMEZONE corrected the problem.
из ian.cormie
Показать ещё 24 комментариев
