Overheating -- Fan not spinning
I have an 80gb CECHE model PS3. The fan isn't spinning up, and it's overheating in 15 minutes or so from being turned on. I know the fan itself works because it will spin up for the "fan test."
Is this a sign that my solder is already cracked, or will changing the thermal paste fix the problem? Or is it something else entirely?
Thanks!
Это хороший вопрос?
Оценка 0
7 Комментариев
Anyone know anything about this???
из
im confused...the fan is or is not spinning while it is on(not during fan test) also have you taken this unit apart at any time?
из
The fan is not spinning when the unit is on. I took it apart to clean out the dust, but didn't do much more than take the case off.
Maybe the thermal paste is so bad that the unit overheats before the heat sensor knows to turn the fan on?
из
Replaced the thermal paste. System behaving the same as before. Dang.
из
Performed YLoD repair. When I turned the system on afterwards, the fan came up. The fan cycled to max speed within 10 minutes, and then I got the "the system is hot" message and an auto-shutdown. Now what?
из
Показать 2 больше комментариев
Добавить комментарий
2 Ответов
Выбранное решение
Cleaning out the dust doesn't always solve the problem. Bearings in fans go out all the time or if you live in a home with cigarette smoke the nicotine and tar can jam it up.
You can pick up a new fan for just a few bucks and replace it.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Right, but I know the fan itself isn't bad because it comes up and runs like a jet engine for the fan test. So it must be an issue related to the heat sensor somehow...
из
My ps3 fan is not spinning when it is turned on is it the fan its self or something else
Оценка 0
Добавьте свой ответ
cowdisciple будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 4
За последние 30 дней: 15
За всё время: 5,258
