Repair guides and support for smartphones manufactured by Doogee.
Trying to get the screen out to replace charging port
My Doogee S59 Pro's charging port was broken by a cheap type C charger, and it has glue all around the screen, which I need to remove to access the Charging board. Does anyone know of something that will dissolve the glue?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Heat! Just apply heat (100C) around the screen for 8 to 10 minutes, then pry on it (gently). I've been trying to get it out for months then saw this video! https://youtu.be/LM5Qae_A5oU
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
hi there, i have the same problem, did you finally replace the charging port ?
из
Добавьте свой ответ
Anchevauls Walker буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 406
