Washed colors/light leaking in one corner
I bought old 27" Apple LED Cinema Display recently with well known problem of screen flickering on higher brightness + sometimes (not all the time!) washed colors/light leaking on right upper corner. I opened it and it was clear right away, that connection on left LED strip is very loose and broke completely when I touched it. I thought that backlight leaking on right side is connected with this.
I ordered spare pair of LED strips to LM270WQ1 (used ones only available), dismantled LCD panel, replaced both LED backlight strips successfully and mounted panel back.
To my surprise: when I finally connected it to computer, backlight is working without any issues on highest brightness setting but unfortunately the right upper corner has still washed colors/backlight leaking. In addition I can see some image persistence as well.
Any clues what is wrong? Anyone had similar issues?
Это хороший вопрос?
@cburza if you should take it apart once more :-) take some pictures of the inside of the screen. Let us see how the diffuser sheets and polarizer sheets are seating as well as the backlights. Details matter when it comes to light.
из oldturkey03
Yesterday (almost two moths later), all of suddenly, the display get back to normal... No pale colors, no brighter light on right upper corner anymore. Nothing was done with display, just normally used day by day.
из Cez
