Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
210вопросов Показать все
Can I use another models MacBook Pro lcd to test?
Hi there,
I own a MacBook Pro 16" 2019 A2141.
It doesn't show any display at all. On an external display everything works fine.
It had a minor liquid damage on the lcd-LVDS connection. I already replaced the LVDS cable, but it didn't resolve the issue.
So I want to try it with a known working display, but the displays are hard to and/or very expensive. I wanted to replace the LCD connector on the T-Con board and I was told it is the same connector as the A1706 A1707 A1708. Does this also mean that I can use their displays just to test if that will be working? Because that will make the job to find one a lot easier!
Hope someone can help me with this question!
Thanks in advance.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Yes, I have used A1990 LCD to test on a A2141 logic board. But. A1706, A1707 wont display or else it boots up to the desktop
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
dustin_mijnders будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 4
За последние 30 дней: 7
За всё время: 70
