Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
85вопросов Показать все
MacBook stuck in the apple logo, with fans at maximum speed
Hi, I have a 2019 macbook pro and it does not start. When you press the power button, the macbook stays in the apple logo with the fans at maximum speed. I have tried to enter DFU mode but there is no way. any idea what could happen?
Это хороший вопрос?
Оценка 1
2 Комментариев:
Hi
Did this just randomly start happening or did something like a liquid spill happen
из
Hi! No liquid has been spilled on the Mac and it hasn't been dropped either, so I don't really understand where the error could be.
из
Добавить комментарий
1 ответ
If you spilled something on it previously, that could be a factor, and it could also be a bad battery, or a cpu/gpu issue. If you previously used it and ran it hard then it most like is a cpu/gpu issue. Hope this helps!
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Borja 1 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 32
