Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
327вопросов Показать все
Why does my screen shut off when I open the computer all the way?
I used my MacBook two hours ago and it was working normally, I come back just now and the screen is black, the touch bar is on, and shut it off and on did nothing. I investigated a bit further and notice that if I only open it partially, the screen comes on. I typed in my password, installed an update and the screen worked the whole time. But the second I try to open the computer all the way it goes black.
Please tell me this is fixable, I work at home and have to use my computer tomorrow to work.
Thanks for your help!
Это хороший вопрос?
Оценка 0
1 Комментарий
Stephanie Joanna possibly a failed ribbon cable or failing solder joints where the cable connects to. Take a look on here for a bit more history on this https://www.ifixit.com/News/12903/flexga... and I bet replacing the cable will fix it. MacBook Pro 13" Retina (Late 2016-2019) Touch Bar Display Cable
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Sounds like you are facing FlexGate! What happening is as you lift & close the lid you stress a cable which was not correctly sized. The stress causes the cable to fail over time. Here’s a deeper dive The Design Flaw Behind MacBook Pro’s “Stage Light” Effect
As the cable breaks down the displays backlight will finally fail getting to a black screen. Plugging in an external display with the lid closed should work via the external.
To fix this you’ll need a new display! I would get to an Apple Store ASAP! As the window on getting this repaired under warranty is getting close to ending. While Apple acknowledged the issue in the 13” the 15” also had problems too!
Here you need to fight for a warranty exception to get it fixed. Be pleasant but firm! if you get NO, ask to speak to the manager and keep working up the food chain! I would go on a Tuesday mid morning as the staff is rested and more responsive.
If you don’t get relief you can replace the display your self it’s just the cost of the display is quite high! $500 USD for a used display and is getting hard to find, a new one is around $750! Which is why getting covered under warranty while a pain is the better answer.
Here’s the 13” extended warranty program 13-inch MacBook Pro Display Backlight Service Program
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Stephanie Joanna будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 11
За последние 30 дней: 13
За всё время: 67
