The Valve Index Base Station is a device used to track the position of virtual reality headsets and controllers. It uses infrared technology to accurately track the location of VR equipment in a room, allowing for a more immersive and responsive VR experience.
What type of connector is used for the base station power cable?
The cable going between the wall wort and the base station had the connector snap in the wall wort. It's a small two prong adapter with a plastic flange that seems like it'd be relatively simple to re-solder if I could find a spare, but I have no idea how to find it. A name or a purchase link would be fantastic. To be clear I am referring to the plug on the other end of the cable from the barrel plug. I believe it is some kind of molex connector?
Female:
Male (this is the part I need to replace):
Это хороший вопрос?
Счет 0
2 Комментариев
A pic would be super helpful
из
Updated with photos. I've done some more digging and I think it might be a molex micro-connect
из
Добавить комментарий
1 ответ
Выбранное решение
This is most likely a molex connector, as you have pointed out.
As far as I can tell, this should be part number 436450200 which you can view and also get a 3D model of on their official website.
Был ли этот ответ полезен?
Счет 3
1 Комментарий:
PS: Had the same issue on mine. I feel like this was a very bad design choice...
из
Добавьте свой ответ
Walter Gray (Shenanigans) буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 30
За всё время: 1,147
