My touch does not work anymore
My mobile samsung j6 had fallen down from my bed to a distance of 2 metres. From then my touch is not working,
but there is no crack on the screen due to it.
It is working as perfectly as it can when I connect it to USB mouse or keyboard.
Is there any way I can retain my touch back without replacing a part?
(OR)
Is there any way I can retain my touch back by replacing a part and what part it can be and where can I get it?
(Even the smallest answer would be greatly helpful to me.)
Это хороший вопрос?
Счет 3
1 Комментарий
My phone has follen down but no crack and and the screen also glowing but touch is not working
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hemasai Duppalapudi sounds like your touchscreen got cracked. Yes, there is a possibility that it is a loose connection on the main board but chances of that happening is slim. You will have to replace the display assembly, which includes your touchscreen. Use something like this video or even this Замена дисплея Samsung Galaxy J6 as your guide. Replacement screens are readily available and prices are reasonable.
Был ли этот ответ полезен?
Счет 3
2 Комментариев:
My phone touch was not working
из
@samsung18678 same answer for your phone!
из
hp lama saya suka nge lag. sentuhannya butuh waktu beberapa menit. buka apk yang menggunakan internet,tidak bisa. padahal penyimpanan masih banyak
Translate Indonesian - English
My old cellphone likes to lag. the touch took a few minutes. open the apk that uses the internet, can't. even though there is still a lot of storage
Счет 0
1 Комментарий:
@bili74026 make and mode for your phone?
@bili74026 merek dan mode ponsel Anda?
из
Добавьте свой ответ
Hemasai Duppalapudi буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 23
За всё время: 1,228
