Apple's successor to the 30-pin dock connector. This cable has been bundled with most Apple mobile products since 2012-2021
USB-C to lightning wiring diagram
Hello iFixers 🙌
I have two broken Apple Lightning cables. One is a USB to Lightning and the other one is USB-C to Lightning.
I'm more or less ok with the first one and it's wiring diagram - it has 4 wires just like the new replacement connectors I got from AliExpress 😁
However with a USB-C to Lightning I feel way less confident - this one has an additional blue wire and here I need your help - maybe someone could share a proper wiring diagram for this case?
Thanks in advance 🙏
P.S.:here are the pics of the new connector
Это хороший вопрос?
Счет 9
5 Комментариев
@insympathy can you post an image of the replacement connector? For now what I have is
Red <==> Positive
White<==> D-
Green<==> D+
Blue<==> Listed as "CC" (maybe sensor wire for Apple's authentication IC (2V?)
из
Hey 👋 thanks for answering 👍
I added pics of the new connector to the original post because I fall led to find a way to add pics to the comments
из
@insympathy you can't -) Pictures can only be added to answers and question. You did the right thing :-)
из
@insympathy looks like that connector doesn't have the connection needed for the blue CC line. You could try and solder the four cables without the blue one and see what happens. I thinks your Apple device may not like it because it can't verify that this is the "right" cable.
из
Did this work with the usb-c cable?
Because i used to customize the cables with paracord to make the more durable, but never did manage to venture to the usb-c ones.
из
Добавить комментарий
1 ответ
Выбранное решение
@insympathy looks like you need a different connector or you could try to "rig it" but it would require some good soldering skills :-)
Here is what I get for the wires
If nothing else you get the USB-C pins from it:
Ground <==> pin 1
Red <==> Pin 9 VBus
White<==> Pin 7 D-
Green<==> Pin 6 D+
Blue<==> Pin 5 CC1
Был ли этот ответ полезен?
Счет 4
6 Комментариев:
Thanks man 🙏 ordered an additional set of 5-pin connectors that support fast charge. Will fix an older USB to Lightning for now 🙌
из
@insympathy That's the spirit!
Remember
REPAIR IS WAR ON ENTROPY.
Let's fix things and save our hard earned money.
из
Couldn't agree more 🙌
из
I have to replace the lightning end of a USB-C to lightning cable - what do I do with the blue wire? there only 4 pads on the replacement lightning tip and 5 wires. I have repaired several USB-A to lightning so I tried omitting the blue wire but no joy.
из
if you have a cable with 5 wires - you need a connector with 5 pins in order to support fast charging - those are also available on AliExpress
из
Показать ещё 1 комментарий
Добавьте свой ответ
in_sympathy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 33
За последние 7 дней: 129
За последние 30 дней: 595
За всё время: 23,877
