Released on June 23, 1996, Model NUS-001, 64-bit gaming console
114вопросов Показать все
How do I get the nintendo 64 to work on modern TV?
I have a Nintendo 64 which is in perfect working order but cant seem to get a picture on my Samsung plasma tv and i have tried searching the channel too. Do i need to purchase a different cable or anything?
Это хороший вопрос?
Оценка 3
9 Комментариев
James Bryant, what cable are you using? The WII cable would work as well as an NES AV/Component cable. Your TV probably has the RCA or S video in, insert the cable into those, make sure that you select the right video source on your TV. Let us know what TV you have in case it should still not work.
из
Im just using the nintendo cable. should i purchase the wii cable and try it?
из
That is the way I would proceed. which Samsung TV do you have?
из
maybe & maybe not because I have a sanyo plasma tv & it works with all my game consoles like my gamecube,wii,& PS3
из
On my sanyo plasma tv the yellow,white,&red are on the side & the top plug-ins on the tv
из
Показать 4 больше комментариев
Добавить комментарий
4 Ответов
Выбранное решение
You should be able to use the standard Nintendo RCA cables (such as used by the Wii and also the SNES). If you get no video when using this the problem may lie with the console or possibly the game. Any dust or wear on the contacts will cause the system to give no video output at all.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
The Wii video cables are incompatible with the N64 due to a different connector. Only the SNES, N64, and GameCube can interchange cables.
из
I'm not exactly sure what the issue is (if your sound is getting through, the TV must not support that resolution) but this should fix it. Or, if your TV has a VGA input an A/V to vga also works.
I have the same problem, except that my gamecube doesn't work with my A/V receiver. It works when I plug it into my TV, though. If your TV has the setting for it, change your resolution to 680P or 480P. Hope this helped!
Оценка 2
some times its the resolution of your Tv its too bigger
Оценка 1
Maybe try different video cables. I'd try RF to see if that fixes your issue. Most smart TV's have an RF port on them. Had an identical issue, Hope this helps.
Оценка 0
Добавьте свой ответ
James Bryant будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 11
За последние 30 дней: 41
За всё время: 45,539
