Why is my mobicel only showing the logo of the phone not opening
Why does my mobicel show the logo after I turn it on
Это хороший вопрос?
Это хороший вопрос?
Hi, try to remove the sim card, and the sd card(if any) and restart the phone.
It happened the same to me with a T-mobile branded phone. If it powers ups ok, then insert the sim.
Был ли этот ответ полезен?
Pode tá apertando o botão de power em série várias vezes sem parar e ele fará o que o processador força a memória para que ele ligue novamente normal
My mobicel Rx17 is showing me just the starting android of it
That is a very common problem with mobicel smartphones, it is stuck on boot loop. You will need to hard reset the phone by following the step by step instructions given on the link below
Mera phone charging nahi le raha hai low battery hai
Mera phone low battery hone ke bad charge nahin leta hai kya karna chahie
Mera phone low battery hone ke bad charge nahin leta hai kya karna chahie nahin on hota hai
try to press both volume up & volume down buttons.
Screen repair
Are you answering the original question, saying to replace the screen, or are you asking how to repair the screen? If the latter, you would be better served to start your own question and ask what you want to know. If this is a question, it does not have enough information, so please elaborate on what you're asking.
За последние 24 часов: 13
За последние 7 дней: 22
За последние 30 дней: 80
За всё время: 2,318
