The Atari 5200 (also called the Atari 5200 Super System) is a home video game console introduced in 1982 by Atari, Inc.
Where Can I Find Replacement 5200 Controller Ports?
Good day, I've been working on repairing a lot of my consoles recently and noticed that the controller ports for my Atari 5200 for 1st and 2nd player are badly damaged, I was wondering if you knew of a place where I would be able to buy just the ports to be soldered on? Thank you for your time and have a great day.
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Выбранное решение
@aslbozz you could check with console5.com or best-electronics-ca.com and see if they have those ports. It is unlikely given the low production rate of this console. The connectors itself are simple DB-15 connector and you can find those at digikey.com and mouser.com as well as many others. The only issue here will be, that you really have to dig for something that matches your console. It's not as easy as just selecting a direct replacement, but it should definitely be possible. Measure the dimensions of your ports and armed with those measurement, start scour those sites.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Thank you so much, I really appreciate the help!
из
Добавьте свой ответ
aslbozz буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 354
