Hyundai's entry-level vehicle. It's available only as a sedan; the hatchback was discontinued after the 2017 model year.
Hyundai accent 2019 ... why does the ABS alarm lights after a rainy da
Hyundai accent 2019 ... why does the ABS alarm lights after a rainy day?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
ahmedhadiabbas1968 it is possible that one of the sensor wires got shorted out. You want to check those sensors/wires for corrosion as well. There is also a possibility, that the rain water carried enough debris with it that there is muck and debris on the sensor. Cleaning it should help. Ultimately, I suggest that you get the OBD on your Hyundai scanned and see what codes pop up. Anything else will really just be a guess.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
ahmedhadiabbas1968 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 81
