Why does my phone dies when unplugged from charger?
My phone only works when its charging. And took time before it start after plugging charger.
Это хороший вопрос?
Это хороший вопрос?
either
1) the battery is on its way out and should be replaced.
2) there's an issue with the lightning flex cable assembly which is not allowing the battery to charge and should be replaced.
3) there's an issue with the recharging circuitry on the motherboard, which is big trouble, as it will require microsoldering repair on the motherboard. your best bet is to get a fully charged battery installed in the motherboard so you can pull an itunes or 3utools backup to preserve the data then deal with the hardware issue.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 13
За всё время: 143
1 Комментарий
It’s probably on life-support
You need to replace the battery
из ismail ali
