How to power up MacBook without power switch?
My power switch doesn't work but It will take a few weeks before I'll be able get a new one.
I was looking for a way to turn it on from the logic board, until I get the new keyboard, but I couldn't find how to do it on my model.
Can anyone help me here?
Thanks a lot
Это хороший вопрос?
Оценка -1
Добавить комментарий
3 Ответов
Выбранное решение
Be aware that if you power up the machine using the power pads and then connect the top case while the machine is powered you could generate a short that could fry the logic board. Instead use an external keyboard and a mouse until you install the new top case.
Был ли этот ответ полезен?
Оценка 2
Look at the picture in this link. You should be able to short across the 2 solder points and it will start up if in fact the power button is the issue. What color macbook is it i may have one for you?
http://guide-images.ifixit.net/igi/5daVK...
Оценка 1
the power pin is the leftmost one from the bottom row. you can use the fan surface as the ground
the diagram is attached on the bottom
Оценка 0
Добавьте свой ответ
Shevcach будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 4,134
