Released August 2018, identified by model number ‎A3902J21.
Dropped them into the toilet... Left earbud now quiet
Hi!
I made a mistake, the earbuds + case fell out of my pocket and into the toilet... I immediately heated them with a hair dryer for about 10 minutes, sprayed contact cleaner and cleaned with isopropyl alcohol, although I haven't taken them apart yet.
I let them dry, everything seems to work but the left earbud is really quiet.
Is it fixable?
Thanks!
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi
It could be a bad battery in the earbud but I suspect that by heating them with a hair drier that may have slightly melted or deformed the driver/speaker
It might be worth waiting a day or so to let them dry if you don’t want/can’t open them
Hopefully this helps
Any questions please ask
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
I have opened them up, cleaned the back of it with iso, and now they are working! Is it worth me opening up the other end of the earbud, plus the other earbud to check for damage or do you think it will be ok?
Thank you!
из
@yotoprules
I would do the same yes
As long as your comfortable doing so
Better to be safe :-)
из
Добавьте свой ответ
yotoprules буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 21
За всё время: 460
