Not showing up in finder
Hi everyone I just got an iPod shuffle 2 and it’s not showing up in finder does anyone know how to fix it
Это хороший вопрос?
Счет 3
4 Комментариев:
Do you have a Windows computer?
из
@andrewsawesome I'm struggling to work out what finder is.
из
@thequacker I see, crapple stuff. I use Windows lol. ITunes, 3u tools but never heard of finder.
из
Добавить комментарий
1 ответ
If your iPod Shuffle 2 is not showing up in Finder, it may be due to a number of reasons. Here are a few things you can try to fix the issue:
  1. Check your connections: Make sure your iPod Shuffle 2 is properly connected to your computer using a USB cable. You may want to try using a different USB port or cable to see if that helps.
  2. Update your computer: Check to make sure your computer's operating system and iTunes software are up to date. If not, update them to the latest version.
  3. Restart your computer: Sometimes restarting your computer can help fix connection issues.
  4. Reset your iPod Shuffle 2: Try resetting your iPod Shuffle 2 by toggling the on/off switch on the back of the device to off and then back on. If that doesn't work, try restoring your iPod Shuffle 2 to its factory settings using iTunes.
  5. Contact Apple support: If none of the above solutions work, you may want to contact Apple support for further assistance.
I hope one of these solutions helps you fix the issue and get your iPod Shuffle 2 connected to Finder.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Sami буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 13
За последние 30 дней: 70
За всё время: 2,375
