This page includes repair guides and technical reviews of Huawei Mate 10 (released November 2017).
broken pins on Huawei Mate 10 motherboard. Still repairable?
Hi all! I'm trying to revive my old phone by replacing the bloated and dead battery and found out about this issue. I know I can still buy a motherflex cable for mate 10 but the pins on the motherboard itself are broken.
Is it still repairable? Here are some photos
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
Выбранное решение
Hi Luke,
It is possible to replace that connector on the motherboard, but it does require some fine skills in soldering, or microsoldering as it's being called nowadays. Generally it's done with hot air rather than a soldering iron, although once it's off you would generally clean and tin the pads with a fine tip soldering iron.
The part itself is cheap and was surprisingly easy to find; here's an example from AliExpress.
Fpc Connector Huawei Mate 10 Pro Charging
I think this is the right one, but it's hard to count the exact number of pins from your photo; you can probably do a better job with a magnifying glass. There are quite a few that come up if you search for "Huawei Mate 10 FPC connector", so pick the one with the right number of pins.
If the soldering job is out of your comfort zone (like it is mine), you can probably get a local repair shop to do the job fairly cheaply; for them, with the right tools and experience, it should be fairly simple.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Thanks! Will definitely find a local repair shop since I'm not comfortable doing the microsoldering by myself.
из
Наиболее полезный ответ
Yes, new connector and ribbon. Hot air station and soldering skills. Not a massive job. If you don’t feel up to it yourself try and find a good repair shop. Some pc repairs will be able to solder a new one on for you too if you have the part.
Оценка 2
1 Комментарий:
Thank you for your help! Will try to find a good repair shop for this.
из
Добавьте свой ответ
Luke Sta Ana будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 188
