Repair guides and disassembly information for Samsung's Android-based cell phones old and new, including the popular Galaxy product line. Get everything you need to repair your Samsung phone yourself.
13241вопросов Показать все
Samsung phone is not starting or not charging
My samsung galaxy Star Plus Model no- GT-S7262 stopped working like 2 year ago. On that time were not known about Firmware issue so we left it like it is now. After 2 year knowing the firmware problem i tried to restart it but nothing happening. Is there any chance to reopen and reuse it?
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
I'm sorry to hear that your Samsung Galaxy Star Plus has stopped working. Unfortunately, it is unlikely that you will be able to get it running again without replacing the firmware. It is possible to replace the firmware with a compatible version, but this can be quite complicated and may require professional assistance. Additionally, there may be other hardware or software issues preventing the phone from functioning properly even if you are able to replace the firmware. I recommend consulting a certified technician for advice on how best to proceed.
Был ли этот ответ полезен?
Оценка 0
@debojit first, after two years your battery will need to be replaced. Second, what made you determine that this is a firmware issue. You did not tell us what you did, that may have caused this. So change the battery, get a USB ammeter plug your phone in and see how many amps it pulls first. Lets see if this is not a different issue.
You can try to update your firmware by following these instructions
Оценка 0
MY phone is not starting and not showing anything on the screen
Оценка 0
1 Комментарий:
@dilipkumar82495 what make and model is your phone? What have you checked and what have you tried?
из
Добавьте свой ответ
Debojit будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 5
За последние 30 дней: 18
За всё время: 46
